Quieter through the gears. Seems to grab up a little tighter in each gear. Shifts are noticeably smoother. Upshifts under mild throttle are smoother, not as much KA-CHUNG shift. No leaks yet, especially with the new crush washers![]()
Unrelated: Thanks Ryan for the Castrol rebate note. Picked up enough to put 5W50 in the 318is for the winter. I usually run M1 15W50, but decided to try 0W40 in it earlier this year. The timing chain started making some noise with that; put the 15W50 back in and it went away. So, thought I'd try the 5W50 as a compromise, plus the rebate makes it $4.31/quart from Advance Auto...
