Results 1 to 2 of 2
Thread: Jingle All the Way - noise from right rear
    SC
    Default Jingle All the Way - noise from right rear
    I have an annoying noise from the right rear on a '95 525i that I can't figure out. It is definitly not a clunk - but a high pitched jingle/rattle ( as if something is loose and rattling around ) when going over a bump. I've elimated the brake and shock by removing both and still getting the noise by rocking the suspension arm. The noise seems to be coming right around the hub - not at any of the bushings. Is this a common noise for either a failed/failing wheel bearing or outer CV joint? Any advice on finding the culprit?
    Hockinson, Washington
    I know there is a water shield for the brake rotor on the front, and i believe there is one on the back as well. That shield could easily create a noise like you are describing.
  1. Replies: 4
    Last Post: 11-24-2008, 09:21 AM
  2. Baffling rear noise, 540
    By jofusfarr in forum 5 Series BMW
    Last Post: 06-14-2008, 01:15 PM
  3. rear car noise
    Last Post: 04-08-2006, 01:01 PM
  4. rear noise
    By old bob in forum 5 Series BMW
    Last Post: 03-10-2005, 06:03 PM
  5. Rear noise
    By jsvizijr in forum 5 Series BMW
    Last Post: 10-04-2004, 09:39 PM
