Results 1 to 10 of 15
Thread: strange sounds from pump
    Default strange sounds from pump
    auto leveling... in 4-5 second cycles I hear a pisst/whirr sound and the engine lowers rpms when it cycles.
    The CH7 fluid is below the screen whe off but wondering if this is normal. Fluid is not real dirty, belts tight pump dont get hot either. Is this normal? If not what do I look for, havent pumped the **** outta the brakes and checked it yet as it is on ramps for me to finish the suspension replacement.
    The CH7 fluid is below the screen when not running but wondering if this is normal. Fluid is not real dirty, belts tight, pump dont get hot either. Is this normal? If not what do I look for, havent pumped the **** outta the brakes and checked it yet as it is on ramps for me to finish the suspension replacement.
    Aug 2004
    Dubai
    this is one of the annoying options in 8 series, I read something somewhere about 8 series that just don't buy the one with the auto-leveling cuz it's pain.
    but I guess in ur case u already have it and u need to figure out whats going on, so as u always say ... go to basics, replace the hydraulic fluid and do a full flush, you can also check for leaks around the pump and the high pressure hoses. hydraulic systems hates air bubbles and that causes the pump to get noisy by time.
    after all the mess u saw in the engine, don't expect to find a perfect maintained hydraulic system too. so you might think about replacing the hydraulic pump too.
    I had that on my E32 750 power steering - which is also with Pentosin because it uses same reservoir and has a double pump for PS and LAD - when I turned the steering wheel to either roght or left side till the end.
    Got a good advise from an old BMW Meister to change the filter in the reservoir and there is another filter in the ASC+T line (small item but costs 50$) and to check the pressure lines to the power steering pump, as he suspected that ine of these copper(?) washers where this hollow screw goes into the pump and hplds the pressure line was tightened too much and squeezed and could hinder full flow.
    That is the small filter
    http://8810.teacup.com/750hiline/img/bbs/0000258M.jpg
    Did that and no more noise.
    after doing conciderable reading I believe it to be the brake bomb. This is on order and I will flush and change the canister filter. I will also remove the small filter and try to clean it out mattering on the material it is made from.
    My fluid looks real ugly and I am looking forward of ridding it of the stuff. A complete change of all fluids will be performed also as there is NO history available at all on this vehicle.
    baton rouge, loserana
    i've seen 7 series with lad make odd noise cycles when someone ****s with the level sensor and gets the system at the wrong ride height
    twas the bomb, no cycling sounds or pump whirring...lots and lots of tiny bubbles that need to come out of the fluid tho. Amazing how the brake peddle feels now, like it has power brakes now. Quite a lot of things to get out of the way to work on it from the top side.
    Aug 2004
    Dubai
    congratulations ... I was wondering what's that sound when I hit the brakes few times, something like a kick feel then a hissing sound, is this thingy the Bomb?
    yes, the bomb is an accumulator to hold pressure for the brakes when the car is off.
    Aug 2004
    Dubai
    so it's normal to hear and feel it when it works?
  1. Fuel Pump Replacement - Strange Fuel Levels
    By BIGRED in forum 5 Series BMW
    Last Post: 07-11-2007, 10:14 PM
  2. Brake pedal has strange friction/sounds when depressed..
    By cosmowagon in forum 5 Series BMW
    Last Post: 08-03-2006, 01:51 PM
  3. my E34 sounds like a ferrari!!
    Last Post: 11-15-2005, 10:03 PM
