Results 1 to 3 of 3
Thread: Turn signal oddity
    Jul 2004
    Kernersville, NC
    Default Turn signal oddity
    Okay, I have been chasing this one for a while.
    With the headlights on, I hit the turn signal for a right turn and the high beams come on, and it only happens when the lever is moved to the hold position for right turns. If I jiggle the lever the high beams will usually shut off. Is this simply a dirty/bad switch or an LKM issue? I have tried cleaning the dust out of the switch assembly but that didn't work. I did not remove the assembly as it appears that the wiring is soldered into the column harness and I could not locate a connector. Is there one? Anyone else see this problem?
    I try to be a courteous driver and not blind oncoming traffic with those death ray high beams. I could just make left turns at night but that might prove to be impractical.
    '95 540iA ~212k
    This is a common switch issue- the grease in the switch is dead and contacts worn. Replace the stalk and be done with it.
    When doing so, beware the wheel only comes off with the key in the ignition... and make sure you don't break the stalks little plastic return lever when replacing the wheel... then you'll be good to go.
    Oh and btw; I think the stalk from any e34 will fit- pehaps even others... check on www.realoem.com Nick
    Jul 2004
    Kernersville, NC
    Quote Originally Posted by genphreak
    Thanks, Nick. There's a '91 525 in a scrap yard near me that I can get the stalk from.
    John
    '95 540iA ~212k
  1. turn signal
    By julian1966 in forum 5 Series BMW
    Last Post: 02-23-2008, 07:15 PM
  2. turn signal malfunction
    By MJR in forum 5 Series BMW
    Last Post: 02-18-2007, 05:38 AM
  3. Turn signal fix?
    By Jer in forum 5 Series BMW
    Last Post: 01-30-2005, 02:05 PM
