Results 1 to 9 of 9
Thread: did somebody re-tension seat belts?
    Default did somebody re-tension seat belts?
    My driver side seat belt does not get back so qick, actually it stops somewhere and before it gets stuck when closing the door, I push it back into the B-pillar.
    Cleaned cpl. belt with detergent some time ago, then after drying sprayed it with silicone spray, helped a bit to retract a bit better, but not as good as I expected.
    Seems the spring is getting weaker.
    Can imagine that while tinkering with that spring it suddenly gets lose and goes off like a rocket.
    Any experience?
    Seattle, Wa
    Me too...
    Jul 2005
    Adelaide Australia
    kev535i south oz
    Lexington, Kentucky
    My driver's side is slow to re-coil. I just may buy a new belt when it gets bad enough. Not sure I want to mess with somethng that could save my life.
    Lexington, Kentucky
    silicone spray on seat belt surface seemed to help a bit. I guess it reduces friction. Even so, I am going to remove the door piller cover and clean etc. to see if that helps.
    T·O·R·O·N·T·O
    Seatbelts have a lifespan. I'm pretty sure I should replace my belts given it's 1988 build date... but I'd rather trust an aging belt than a wrench monkey to change it out.
    Aug 2005
    West Portland, OR
    Any experience?
    Mine goes up about 1/2 and then i MUST push it up or it sorta jumbles around and never gets pulled in, but I only sit there for about 4 seconds pushing it in slightly right up against the retractor slot.
    EuroLux:. Private Detail
    Silicon spray done already. Pulled it out completely and washed the compelte belt with a soap and a lot of dirt came out. Then let it dry and then sprayed with silicon to reduce the friction, pulled it out several times while spraying.
    Removed door covers, checked the angle the lower part was installed etc.
    What I found out, that apparently the part in the B-pillar could be the culprit where it slides throu, because when I losened the pillar cover and pulled the belt there, it rolled up completely.
    Have to dig into that matter again.
    Only drivers side is making the problem, apparaently as this belt has been used always compared to the other seats.
  1. Frt Seat Belts Interchangeable?
    By 95///M3 in forum 5 Series BMW
    Last Post: 02-26-2007, 07:05 AM
  2. motorsport seat belts
    By postjay in forum 5 Series BMW
    Last Post: 02-13-2007, 05:17 PM
  3. seat belts
    By kev535i in forum 5 Series BMW
    Last Post: 06-25-2006, 08:33 AM
  4. seat belts
    By serpentine in forum 5 Series BMW
    Last Post: 05-22-2006, 04:33 AM
  5. New rear seat belts on the 'bay
    By Mike H in forum 5 Series BMW
    Last Post: 12-19-2004, 09:33 PM
