Thread: my bmw 540i runs rough when it's cold
    Default my bmw 540i runs rough when it's cold
    my 1995 bmw 540i six speed runs rough when its cold outside (below 30 F) and the motor is cold. it will idle below 500rpm and even stall. the check engine light even comes on. after the car has warmed the light will go out and come back on occaisionly, like when stopped at a light. if anyone can point me in the right direction i would be very thankful. it has brand new O2 sensors and the airflow meters were just cleaned. it otherwise runs excellent.
    my email is
    nikog@adelphia.net
    So. California, USA
    How did you clean the airflow meter? As far as I know, it has a thin wire inside and has no maintainable part.
    (SOLD) 92 525ia M50 | NGK plug | JVC AR560 | EAT chip | California
    USA
    try the air intake temp sensor and the coolant temp sensors.
    search "intake gaskets" or "intake leak"
    bookmark this link:
    http://www.bimmernut.com/wwwboard/e34/si.html
    Apr 2004
    Reston Va
    Classic 4.0 Intake Manifold Gasket Leak symptoms. Do as Jeff suggests. There are volumes here and on other sites discussing this issue. I had the same issue with my 4.0. This is the time of year when it pops up on everyone.- JT
    Johntee540
    1994 540/6 Black - Tan - 199k
    Cardomain Site: http://www.cardomain.com/ride/737181/1
    Albany, NY
    Had the same exact symptom as you. Did the intake gaskets and PCV plate and now life is good.
  1. runs rough cold
    By Ryan12345d in forum 5 Series BMW
    Last Post: 08-02-2008, 09:16 PM
  2. 1992 525i project runs rough
    By wiebuschk in forum 5 Series BMW
    Last Post: 12-19-2007, 06:15 AM
  3. Help!!!! '93 M5 runs rough/stalls when warm.
    By m3driver97 in forum 5 Series BMW
    Last Post: 10-09-2006, 06:43 PM
  4. 1995 525i runs rough at startup
    By ruffbunch in forum 5 Series BMW
    Last Post: 09-09-2006, 08:08 AM
  5. runs rough
    By jippijak in forum 5 Series BMW
    Last Post: 03-06-2006, 06:48 PM
