Results 1 to 10 of 11
Thread: Cold Starts
    Dec 2006
    Waterloo, ON Canada
    Default Cold Starts
    I have searched through everything on this topic (and there is a lot), but there does not seem to be anything I can find to help diagnose my specific problem....
    On a cold start, my E34 will idle at 1,500. After it warms up, the idle goes up to 1,800 and runs perfectly. On a cold morning (below freezing), it does the same thing, but I have a lot of difficulty getting it started. It has always started so far (fingers crossed) but sometimes takes 5 - 10 tries, holding the key for 20 secs or so. It does not always happen, but on enough occasions to make me wonder if I will get to work !!!
    Any suggestions for this??
    DJ
    USA
    WHOA... that idle speed is WAY too high, sounds like there is a massive vacuum leak somewhere. i believe your engine's natural idle speed is between 700 and 800 rpms.
    agreed! Look/spray for intake leaks
    Dec 2006
    Waterloo, ON Canada
    Quote Originally Posted by BillionPa
    Really??
    When I questioned my "BMW mechanic" he said that it should be this high for an automatic, and a standard has lower RPM
    Derbyshire, UK
    Quote Originally Posted by kwbimmer
    Christ, no. My automatic 525i idled at about 850rpm. Sounds like a serious vacuum leak -- check the rubber intake boot and all vacuum hoses for cracks -- or a sacked Idle Control Valve.
    1997 535i V8
    USA
    sounds like the "mechanic" needs to read his manual.
    cracks after the air flow meter in the intake boot, or a punctured or disconnected vacuum hose would do it, possibly a cracked intake manifold or disintegrated gaskets.
    i think there is a spring in the idle control valve. if it corrodes to nothing then any signal to open it will open it completely like when you are starting the car, and the idle will jump to 1500ish...
    Albany, NY
    Also see my posts on the fuel line check valve here:
    http://www.bimmer.info/forum/showthread.php?t=28670
    You may have both intake leaks and fuel drain back problems.
    cracks after the air flow meter in the intake boot...
    I don't want to anger any of the grand masters but my boot was cracked and all it did was give an annoying hissing sound. My idle was still constant at around 900 rpm's. I would eliminate that part as a suspect.
    Jeff
    I prefer to be misunderstood rather than having to explain myself all the time...
    USA
    thats why i added more places to look, because a crack in the boot can still be throttled by the ICV. i really have never seen an idle that high caused my any kind of intake leak, there is most likely more to the problem.
    O.C.
    sounds like something that should be variable is sticking.
    But a better description of the problem would help too. More info pa-lease
  1. ticking on cold starts
    Last Post: 07-16-2007, 11:37 PM
  2. grinding sound when car starts / cold
    By gymkata in forum 5 Series BMW
    Last Post: 12-05-2006, 08:58 PM
  3. starts to look more like a BMW
    By eurodreamz in forum 5 Series BMW
    Last Post: 04-15-2006, 08:09 AM
  4. M50 starts! but WTF!
    By fujioko in forum 5 Series BMW
    Last Post: 04-03-2006, 12:18 AM
  5. Now the fun starts
    By Peter 540 Touring in forum 5 Series BMW
    Last Post: 02-17-2005, 09:57 PM
