525i 1995.I have a small coolant leak somewhere and is collecting on usual drip pan.Last night changed seals on the expansion tank,hope this is it.Takes forever to bleed this system.On cars I ve had in the past you turn the heat wide open,but last night it was 22degs out and I couldnt get any coolent flow.Finally I went out ran the car hard got some flow and was able to bleed the system,but my heat is not getting real hot.Noticed the supply hoses to the heat valve are not full of fluid?Easy to pinch,where is the flow direction?thanks.
