Results 1 to 3 of 3
Thread: Control Arm Replacment (help!)
    Apr 2004
    Default Control Arm Replacment (help!)
    Gentlemen:
    I am going to try to replace my Control arms this weekend. I have a 525i m 91 and just purchased steel lemforders from BMA to replace my aluminium control arms. I have read everything on this site, have a Bentley and reviewed Bruno's site.
    My only question is:
    Should one replace all the nuts and bolts and washers too? Should the bushing bolt washers and self tightning nut be replaced? Should the three bolts holding the "steering" plate that mates to the strut be replaced? Bently suggest the steering tie-rod arm is to be disconnected, is that necessary?
    You advice would be most appreciated.
    Best regards,
    Helm
    Default welcome
    Hi Helm,
    It wouldnt be a bad idea to replace everything but for sure the self locking nuts. The 3 bolts are optional but I would if redily available.
    I did the thrust arms in mine and didnt remove the tie rod, might have to for clearance if replacing both.
    Good luck!
    Jeff
    Apr 2004
    Default Thank you Jeff, I'll see if I can get it from Dealers here!
    Hi Helm,
    Good luck!
    Jeff
    Thank you for the "Welcome", but keep forgetting my password so have to re-subscribe for about the third time!
  1. Help on water pump replacment H&B 325s
    By 1981323i in forum 3 Series BMW
    Last Post: 10-03-2008, 11:04 AM
  2. Sold 540, Help locating a replacment E38
    By 525SEI BRIT in forum 5 Series BMW
    Last Post: 09-08-2008, 10:27 AM
  3. Help with wiper linkage replacment
    By mjfeeney4 in forum 5 Series BMW
    Last Post: 01-01-2006, 05:27 AM
  4. fuel line replacment fix
    Last Post: 10-21-2005, 08:28 AM
  5. air bag wheel replacment ?
    By ROTBMR5 in forum 5 Series BMW
    Last Post: 07-26-2004, 11:20 PM
