check for the casting ID number on the block. the alusil blocks have different numbers than the nikasil blocks.
its on the right side of the block, above the coolant drain plug.
1 725 963 or 1 742 998 are nikail castings for the 540, if the casting ID is NOT one of those, the block was replaced under warranty.
