Results 1 to 2 of 2
Thread: Venturi Effect
    malaysia
    Default Venturi Effect
    I replaced my 2.8 air mass with a 2.0 unit and using a g-tech meter, managed to shave off almost 1.2 secs for the 0-60mph time. I managed to clock 8.6s (M52 engine block, ported head, 5hp-18 ZF tranny) in my e34.
    Is this due to the venturi effect?? Smaller diameter, quicker air velocity??
    Rgds
    Albundy
    Yup, and this principle has also been used to create a vacuum for various archaic applications. In a Venturi tube (as is commonly termed) you can pull a vacuum with a little rigging by inserting a valve at the constriction. The pressure in the larger DIA tube is reduced went air flows to the smaller DIA. tube. The problem with this type of setup is that in creating a vacuum, air has to be released and it is freakin' loud.
    Just for the hell of it, consider a very crowded room where people are squeezed together. As soon as a door is opened, people begin to exit. The squeezing (pressure) is least near the door where the motion (flow) is greatest.
  1. M20 hall effect sensor - how nessesary?
    By billy in forum 5 Series BMW
    Last Post: 02-01-2008, 09:11 AM
  2. perf chip effect on m20 525
    By [1990]525 in forum 5 Series BMW
    Last Post: 08-07-2007, 05:28 AM
  3. Slightly OT: Effect of LSD on torque steer?
    By Adnan in forum 5 Series BMW
    Last Post: 06-15-2007, 10:05 PM
  4. subframe bushings. effect stability?
    By fujioko in forum 5 Series BMW
    Last Post: 05-06-2006, 12:20 PM
  5. Cause and effect...
    By NoSpeedLimits in forum 5 Series BMW
    Last Post: 05-18-2004, 02:14 PM
