Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: steering column/starter kill
    Default steering column/starter kill
    Does anyone have a detailed wiring diagram of the steering column? I am installing a starter kill device (similar to the keypad used in the transporter). I will post a writeup when its finished, giving detailed instructions with pictures if anyone is interested.
    thanks alot, hopefully this will work out great.
    Sep 2006
    Colorado
    You have my curiousity piqued...
    Love to see what you have when you are done.
    Aug 2006
    thats not the best place to cut into wiring, its where a thief would look, plus if you cut into the starter wiring, you can just bypass it under the bonnet at the multi pin socket
    youre better disabling the fuel pump and the power to the ecu
    I know how to hide the splices, im not a retard.
    and how many thieves would know where to bypass it?
    this has the option of disabling the fuel pump
    Aug 2006
    Quote Originally Posted by indierthanthou
    i recommend you loose the attitude, I am only offering my opinion and my experience, in that there are better systems to disconnect as the starter wire near to the key switch
    and if I may say so, you are rather naive to think that a thief knows less than you do, and is unaware that you can still start it from the multi pin connector, or jump start it
    you didnt mention you were disabling the fuel so we readers of your post had to guess,
    you cant be that bright if you are unable to use a multimeter and work out what wire is what - so listen to people that have the skill you dont
    Dec 2005
    DC Metro
    Lotsa people stealing 89 535's near you?...
    USA
    settle down there guys......
    the starter wire should be the black/yellow one.
    if you want to add something in there, wire the thing into the kickdown switch, so it has to be pressed to even activate the unlock device (then you can remove your foot before starting obviously)
    also a discreet wiring into the fusebox to kill the fuel pump fuse without outward visible signs is a fantastic idea.
    if you wanna fool a theif, wire the starter kill into the depths of the wiring loom just before it gets to the fuse/relay/whatever the hell it gets to. that way it will be hard to trace, and hopefully disable the diagnostic port pin as well (if not, disable that anyway)
    and if you REALLY wanna go nuts on this thing, wire the thing into the crank position sensor wire in the e-box, that way if they manually ran the fuel pump and the starter, it would still not start.
    have fun!
    didnt mean to come off as a jerk. my apologies. as far as the multimeter goes, yes i am able to do that, im basically just impatient and lazy (feel free to flame me for that one, say i dont deserve an e34, etc) when i can get what i need from a forum.
  1. Anybody Know how to reassemble a steering column?
    By Five2FiveTD in forum 5 Series BMW
    Last Post: 01-28-2008, 04:18 PM
  2. Replies: 7
    Last Post: 07-16-2006, 05:26 PM
  3. Steering column dis-assembly
    By Zeuk in Oz in forum 5 Series BMW
    Last Post: 03-02-2006, 05:38 PM
  4. HELP PSE Steering column lock!
    By ggrigg in forum 5 Series BMW
    Last Post: 03-14-2004, 03:50 AM
