Hello. With the winter coming, I went through the usual locks-not-working-properly-phase when its raining on days and sub-zero at nights. Usually cleaning the locks and aplying some anti-frost makes the locks work. This time around however after using these, the driver door fails to close properly. The vertical moving part (dunno the terms, english isn't my first language) that should lock into upright when the door is closed fails to lock into the closed position. When you manually turn that part in other doors, a latch of sorts locks into place from above, this is not happening on the drivers door.
I've earlier had some problems, especially during winter time, with locks jamming into the closed-position, but never this way around. I don't have a garage and I'm not going to open the door in the dark, cold and rain, so I'll have to check it up indoors later. If anyone could enlighten me if there is some known breaking part in there or something else I should be aware of before I start removing the door panel I would appreciate it. I'm lazy enough to try to avoid extra work, so if there's some part I'm going to have to replace anyway, I could do it in one door-opening session.
And yea, as you can figure out, I'm just a poor student who loves his car. So sorry if this is too basic for you guys![]()
