your bulbs or something is out because they do light up.
Just something I noticed:
My On Board computer doesnt have any lights on the buttons , only the little screen lights up , but in the dark its hard to see the buttons !!
Not only this , the three dials ( left/right temperature and fan speed) dont light up either .............. is this a fuse problem or did BMW just forget this?
Do you think it could be a fuse ,
Its very unlikely that ALL these bulbs would go out at once
Did I mentionthat all other bulbs are ok (even the ones onthe 3 sliders for vent control work), just this section isnt working(temp dials , fan speed,OBC) dont work.
Anyone Have a fuse diagram?
Remove the OBC per Bentley and replace the bulbs.
Originally Posted by Drooby
Dont Have Bentley's , Can you please post ?Originally Posted by Warren N.CA
thanks
http://www.bmwe34.net/e34main/mainte...nel_lights.htm
Kurt
95 525ia
thanks, i'll try it today ! (if the rain stops)Originally Posted by KurtM
Went to the dealer to get the bulbs ,
>>>Man sometimes I think , they dont know what their doing over there!!
First they told me that the OBC takes 4 bulbs , I said that I knew it took only 3 ( from the forum) any way , i got the 4 just in case ,
NEXT , they said the cluster panel had one bulb THAT WOULD HAVE TO BE SPECIAL ORDERED !!!!!
I said wow , you are the only dealer in a 300 mile radius you should have all the parts , but they could only say that this is a difficult part and it would only be available in 4 days if i ordered it
to make a long story short , after opening the cluster , turned out the OBC only took 3 bulbs .........AND THE ONES THEY GAVE ME WERENT THE RIGHT ONES , they fit inside but were a diiferent volt and ampere!!
just for curiousity I opened up the panel and followed the instructions on Bruno's site to get to the other bulb .....
when i saw it , i knew i could find it somewhere , so just as a long shot < I called Autozone and they had it !!!
NOW everything looks great in the dark !!! first time for me to see colors in the dark in my beemer !!!
I noticed another thing though , the A/M switch next to the automatic shifter doesnt light up , is it suppose to be this way or .........................????
thanks for all your help !!
