Results 1 to 8 of 8
Thread: Transmission Gurus HELP!
    May 2005
    Jet City
    Default Transmission Gurus HELP!
    I am getting ready to do a transmission service on my '98 328is. Build date 1/98
    It has the A4S-270R, 4 speed automatic in it and is identified with the GREEN data plate.
    It's a GM hydramatic (built in France of all places).
    data on the plate as follows;
    96018422 SY
    F41-5360569
    Casting number forward of the data plate is GM 96 017 506 11
    MY DILEMMA;
    According to the E36 Bentley manual the "green plate" trannys use the "lifetime fluid" and black plate use Dexron III (same as in the the E34 manual).
    Then they follow with that statement with, the factory "may" have used the "other" fluid in some cases, leaving the green plate/black plate threory out the window.
    To add to the conflict of identification, the Bentley manual directs me to a sticker on the sump pan for more "definative" information and reads as follows;
    "WARNING, Permanent lifetime fluid blah blah blah, no need for periodic changes or topping off etc"...............BUT it's followed by, and I quote,
    "USE BMW OIL P/N 83229407858 or 83229407859 (DEXRON III)"
    This transmission sounds like a plain old GM 200R4 that runs on DEXRON. Ironically this is the same trans they used in the 318i! (But not the 325)
    I'm leaning toward following the sticker on the sump which would be the last and most recent form of identification during the build process at the factory..
    Is there a guru on board that can steer me in the right direction?
    Thanks!
    DJ
    Spasso
    530iT, 525 5-speed , 328is.
    I'm no guru but know what trans you have. Dexron III is the fluid.
    Whoever first implied that any oil was "lifetime" ought to have a slow vascectomy with a rusty razor blade.
    Nov 2006
    New York
    BMW used a few different types of "lifetime" fluid, so the first step is determining which was used in the tranny. I used to have a list when i worked for the dealer but i think i left it in my desk when i quit. Call Bavarian Autosport, they can identify which fluid you take, which i believe for your car is made by shell and comes by the 5 liter container. They also sell it for much less then the dealer. I believe it runs 100-120 at bav for the bottle
    Too many cars that need work... Looking for a beater E32/E34/E36 to use while i finish a couple projects
    May 2005
    Jet City
    Quote Originally Posted by Spasso
    (A)PER THE MANUAL,
    "the factory "may" have used the "other" fluid in some cases", leaving the green plate/black plate threory out the window.
    (B)THE STICKER ON THE SUMP,
    So what I a getting out of this is
    (A) The factory wasn't consistant in which fluid was used for THIS particular transmission and
    (B) Per the sticker on the sump, IN THIS CASE, BMW is calling DEXRON III a "lifetime" fluid.
    Good advice on making a few phone calls but I bet dollars to doughnuts that as soon as I mention a GREEN data plate they are going to say, "You need the Special Shell Fluid at 30.00 a quart", even though the WARNING sticker on the sump says DEXRON III
    I would be inclined to go with the Shell fluid if the 5 speed automatic for my E34 IF it had a GREEN data plate because BMW is CONSISTANT in the recommendation from one model/type to the next for the E34, GREEN PLATE/BLACK PLATE.
    Oh well, I guess it's time for some phone calls.
    Thanks for the input everyone.
    DJ
    Spasso
    baton rouge, loserana
    if it was mine id run a good dextron III maybe a synthetic like redline or royal purple, i put a little more stock in the special fluid ******** when it's in a newly designed tranny, and not in a design that's been in production for 5 or more years with good old off the shelf dextron III in many bmws plus the god knows how many other makes in one form or another
    May 2005
    Jet City
    Thats the way I'm seeing it.
    It's the same EXACT transmission as used in the 318i from '95 to '99 and I haven't read anywhere that they used the "magic", 100 bucks a quart Shell semi-synthetic in those.
    I think I'll just go with the sticker on the sump of the trans that says DEXRON III
    Thanks, DJ
    Spasso
    thats my vote too, just change the filter and fluid that comes out and dont flush the whole f'king thing so you dont have failure.
    May 2005
    Jet City
    Just orderd the trans kit plus all the parts and radiator for a complete cooling system rebuild.
    Radiator, water pump/w metal impeller, T-stat, metal T-stat housing, idler pulleys, belts, hoses, temperature senders, trans kit, micro filter, oil filters, fan clutch removal tools, kitchen sink etc....................free shipping, all for less than 600.00
    Everything is working fine except for cooler than normal operating temps which to me indicates a t-stat stuck open.
    No evidence of previous work done on the cooling system so I think I'll head off a future failure by going with all new parts.
    The car just passed 100k so on the advice from those that have been there already, why not.
    Spasso
  1. M5/S38 Gurus Come
    By ILoveMPower in forum 5 Series BMW
    Last Post: 07-31-2007, 08:42 AM
  2. Any E39 gurus out there?
    By valvesprung in forum 5 Series BMW
    Last Post: 09-21-2006, 10:23 AM
  3. LKM Gurus, Help Please......
    Last Post: 04-19-2006, 03:22 PM
  4. Problem for all you DME gurus out there
    By BigTim in forum 5 Series BMW
    Last Post: 10-06-2004, 10:53 AM
  5. OT: GM 4T60E auto box problem - help question for the transmission gurus
    By Anthony (M5 in Calgary) in forum 5 Series BMW
    Last Post: 04-26-2004, 01:18 PM
