Thanks, I'll check into this until I can get it looked at.Originally Posted by Russell
CRC belt conditioner seems to reduce the squeal on a cold start. Spray in on pullies and belts and it seems to stop start up squeal. Not sure how long it lasts. It is a clear thin substance that dried slightly tacky. Advance or Autozone has it for about $3.
You say 'constant background noise'. Does that noise change with engine speed?Originally Posted by Russell
I swear mine sounds like either the alternator or tensioner bearings. I guess I have to wait until taking delivery in January to see for sure.
does not seem to change with rpm. however, it is added to by other sounds so it it hard to picky out specific sounds. Just seemed quieter when the tensioners were replaced.
