Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: m30b28 on my e32?
    Nov 2006
    Romania/Constanta
    Default m30b28 on my e32?
    Hi everybody,i replace my engine m30b34 with m30b28.The m30b28 is from a e28.When i replace the engine,i change the oil filter canister and the oil pump between them.It is posibble to lose oil presure because of this? My car was 735i/e32. PLease excuse my english.
    The M30B35 engine has 3.500 cc while the one from the E28 has 2.800 cc or so.
    Maybe the oil pump is smaller, but not sure.
    Compare the part numbers of both engine pumps here
    http://www.realoem.com/bmw/select.do...938848d4d39ea1
    Nov 2006
    Romania/Constanta
    Thank you verry much.
    Nov 2006
    Romania/Constanta
    The oil pumps are diferent,but i think the problem is the oil filter canister.If someone knows something about this,please help me.Thank you.
    For the oil filter canister you can use any and install it where you have space.
    Important is that the canister has a ball valve which keeps the oil in the canister when engine is switchted off. This is important that immy on starting you have oil available which is then pushed onto the camshaft, otherwise it takes a long time to get the oil from the oil pump to the cylinder head.
    Here it is explained, link from my website
    http://www.e32fixes.com/results.asp?...ow_fix&fixid=5
    Nov 2006
    Romania/Constanta
    Thank you again mis
    From what you told me i undrestand that the shape of the oil filter canister dosent matter in this case... i must see if that valve is ok... Thank you again mister Shogun.
    Nov 2006
    Romania/Constanta
    From what you told me i undrestand that the shape of the oil filter canister dosent matter in this case... i must see if that valve is ok... Thank you again mister Shogun.[/QUOTE]
    Nov 2006
    Romania/Constanta
    Nov 2006
    Romania/Constanta
    Thank you again mis
    Aug 2005
    West Portland, OR
    EuroLux:. Private Detail
