Results 11 to 20 of 22
Thread: Christmas list tool recommendations
    Elm Grove Farm, NC
    Quote Originally Posted by bbig119
    You're probably right about the impact. I'll be putting my lugnuts on and torquing them to 80-90 ft-lbs, so its not gonna have to break super tight lugs off. Dave, you think your $70 job could do 80ftlbs?
    Honestly, you're better off using a 1/2" breaker bar to do lugbolts- then torque them down with your 1/2" torque wrench. The electric impact wrenches are not all that great- corded or cordless (IMHO). I have a Dewalt corded 1/2" impact and it has trouble breaking loose lugnuts that are more than about 100 lb/ft- or those that have a little rust/corrosion holding them on...
    If you have a cordless drill, then just get a 3/8" socket adapter bit (sort of like a screwdriver bit with a 3/8" square socket holder on the end)- stick the 17mm socket on there and use this to spin the lugbolts on and off- AFTER loosening them with the aforementioned breaker bar. I have done this many times and it works great.
    If you're looking to augment an already decent tool collection- I'd highly recommend "wobble" socket extensions and a good collection of gearwrenches. The wobble extensions used to be really hard to find- but I saw a set at Advance Auto the other day, I think it was 4 pieces- 1/2", 3/8" X2 and 1/4" for about $10. Same with gearwrenches- they are available at alot of stores now.
    Bret.
    Aug 2006
    Champaign, Illinios
    It doesn't always have to be about wrenches and impacts. Detailing products imo are just as important. Maybe because I might have a brain anyurism if I find any sort of dirt, dust, swirl, or imperfection in my paint.
    Thanks to this.
    http://www.properautocare.com/74uldema.html
    Its a good polisher for beginners since it isnt very abrasive and you wont damage your paint, though it wont remove the swirls only mask them by robbing the light relfection.
    Now, this will turn your car into a Mirror.
    http://www.properautocare.com/makhigspeedp.html
    Though use extreme caution, when I first tried it on my Dailydriver i burned through the paint and damaged it pretty bad. Need a soft touch with this.
    None the less great products. I would love some extra Zaino for xmas too.
    The Milwaukee one(18v #9079-22) I ended up with is good after the factory exchanged the first one that was not. It removed the head bolts on my M30 and it will loosen lug nuts. Retails for $350, I was lucky and paid half. You should be able to get one for somewhere in between.
    Jun 2006
    Frederick, MD
    Buy a nice air driven impact and get yourself a pair of $8 hearing protectors...AND MAKE SURE YOU USE THEM!!!!
    1990 535i
    117,000mi
    Feederick, MD
    If it has **** or tires, you are going to have problems.
    Long Island, NY
    I'd like to do air, but I'm in an apt complex which means two things in terms of going with air. 1) I'm not sure if the noise of a compressor would be a problem, and 2) I'd have to drag a long extension cord out of the apt to get power for the thing. Its doable but not ideal. At this point air just isn't the best option, so I either go cordless for some of these things or do it by hand-- which is fine. There is a limit to what kind of work I plan to do in the apt parking lot right now. If and when I get my own driveway and garage, I'll seriously look into going with air tools.
    '94 540I 6spd/205000 miles
    PA
    Guys - I found that if you go to AutoZone to their tool aisle look at the GreatNeck products. They are EXACTLY the SAME as Duralast, bout about 80% cheaper. I bought a 100 piece tool set with 1/4, 3/8 and 1/2 ratchets with a giftcard and I ran into some same or something and got the whole set and I had a $5 credit remaining on a $35 gift card. I just went out yesterday and bought the metric deep socket set, an extendable mirror, pickup magnet, among other things.
    Minneapolis, MN
    Stay away from the cheapo air wrench packages at Sears. I got one for free (ratchet, impact wrench,etc.) with a big compressor that I bought. The free coiling hose cracked immediately (although it was pretty damned cold out when I tried to use it) and the impact wrench really stinks. Going to put a bigger impact wrench on this year's list.
    1992 BMW 525iT (sold)
    1998 V70R
    NEPA
    go ingersol rane. craftsman air tools blow donkey balls.
    Long Island, NY
    Thanks for your help so far, I definitely think some of those torque wrenches from harbor freight will fit the bill!
    I'm trying to find a floor jack though and its kinda hard to pick out what's good and what's **** from looking around online.Bill had a post a little more than a year ago recommending this jack, but it doesn't appear to be available from partsamerica. So, back to the drawing board. I've heard mixed comments about craftsman, and if possible its worth while getting jack with a universal joint. I found a couple others at parts america that look decent-- what do you think?
    http://www.partsamerica.com/ProductD...tnumber=280039
    http://www.partsamerica.com/ProductD...tnumber=640757
    There's no particular reason why both are from partsamerica other than the fact they have a decent selection of jacks.
    One think I should point out is that I don't have a garage and live on the second floor of an apartment building. Having a lightweight jack in this case is appealing, but I don't know if its a bad idea to use on these cars.
  10. #20
    Default I buy a number of floor jacks every year and 2 other mechanics that
    i know also go through a number of them also. As far as something light enough to be hauling up and down stairs, this combination aluminum steel 2.5 ton jack is a very good one for the price. One of other mechanics i share info with has one and likes it very much. I have an all aluminum jack that really isn't quite enough for lifting e34's very often. The one that would probably meet your needs best is this Torin
    If you shop around on the net you can probably find it for less elsewhere. I remember seeing it for 99.00 one time. The floor jack that i like the best for the price is too heavy to carry up and down stairs and its being dropped by parts america but the Checker's store's still have them in stock and will usually discount the price substantially to get rid of them.
    Edit, Omega also makes very good floor jacks and i like this one alot for going under lowered bmw's... its very low. But its quite heavy and wouldn't be a good choice for what you want.
  1. Specialty tool house recommendations?
    Last Post: 03-13-2007, 11:51 AM
  2. OT: What I'd like for Christmas...
    By pingu in forum 5 Series BMW
    Last Post: 06-28-2006, 11:27 PM
  3. Air Compressor & Tool Recommendations
    By Evan in forum 5 Series BMW
    Last Post: 04-15-2006, 05:41 AM
  4. Basic Tool List for BMW DIYers
    By dternst in forum 5 Series BMW
    Last Post: 03-06-2006, 10:40 AM
  5. Tool list
    By Steve N in forum 5 Series BMW
    Last Post: 04-01-2004, 11:56 AM
