Originally Posted by
yy101
, but I was just asking the question whether peeps here do rebuilds on it based on a mileage interval or a till it breaks mentality.
My experience has been, as the mileage builds up on an engine it loses power, gets noisy, runs rough and starts to leak. I ran a Datsun 240z (straight six) to the point where the compression was so low I had to use starting fluid to get it running every morning and everyday afternoon after work. It was a daily driver.
Nothing ever broke, it just wore out.
When I finally did change the engine I tore apart the old one and measured up to .0011" bore to piston clearance on numerous cylinders. It should be .003 to .005" max new.
The rings were completely worn out and a few were cracked.
So my point is, "IF IT AIN'T BROKE, DON'T FIX IT".
Why create an uneccessary expense, an expensive one at that, to your budget if it isn't required? Save your money for the transmission job and suspension rebuild you'll be doing in the future instead.
There comes a point when running a tired old sick engine will no longer be economical from a practical standpoint, (i.e. dumping gallons of oil in it per week). You'll know it when the time comes. In the mean time, DRIVE!!
Spasso
530iT, 525 5-speed , 328is.
