Hey guys - my car bleeds oil - it has for the last year +. I am building (slowly) that other engine to swap in, but I was wondering -
It looks as if its the timing cover gasket, but I can't tell very well. There is a wet oil saturated area on the front of the block, about 1" wide, right where the iron block meets the aluminum timing cover. However, it starts up high, at the head. However, I don't think the head would be leaking oil to the outside, especially since I have no coolant loss or pressurizing of the cooling system at all. So, I really think my timing cover gaskets are peacing out (i think I almost see a tab of paper stickign out, so maybe it ejected the gasket over time, I dunno).
Are these replaceable with the motor and head in the car? What about the front seal that goes around the crank shaft? Is it even worth it? Should I just deal with some leaky oil until I get my other engine done (summer)?
