oh, and if you ARE going to remove the oil filter housing and want to spend some extra cash, think of investing in an Amsoil bypass filtration system.
depending on how much room is in your engine bay you may or may not be able to fit one. i have the AC removed, so there is tons of room, but the bay is pretty cramped. im still pretty sure one can be fitted somewhere with all the oe hardware still in there, but it may be tricky.
advantage? with 9 quarts of high TBN 0W40 oil and 2 massive filters that get pretty much anything, you could easily go 20000 miles per change, with less engine wear than a conventional 5K oil change would generate. you could also get the add-on pre oiler which squirts oil into the cylinder head before the starter engages, so you have about 80% less cold start wear.
that really wasnt pertinent to your problem was it?
