Yes you'll need to remove the flywheel cover first. If I remember right there's 4 bolts holding it on. Once that's off you'll be able to get at the rest of the sump bolts. Don't worry about the gearbox oil or clutch. They are not in the way, and won't leak out. Trust me! By the way, are you also in the UK?
HTH,
Shaun M
