Hello All !
May be you can help me? I own a 525 iX touring (e34 with m50b25 engine, I hope) It is european model. Yesterday suddenly it started overheating, the temp needle goes to red area, the temperature warning goes on. To day I did little study. I did run the car for 10 min or so, it warmed up and temp needle was at 1/2, than I got the road and the teh needle went up to red area. I had AC on. Then I switched off the AC and turned on full interiro heating. The temp needle came in between 1/2 and 3/4 marks. As soon as I turned of the heating it went up to the red area back. I stopped the car and on running engine opened the hood. It seems to me that the fan was not running to fast, even the temp needle was at the begining of red area. I COULD STOP THE FAN BY HAND AND EVEN SPIN IT BACKWARDS WHILE ENGINE WAS RUNNING. Also, when first time (after cooling down overnight and before I did all of above) turned on the engine, while idling auxilary fan went couple of time on , but after I never heared the aux fan voice. The big hoses connected upper left and bottom right corner of radiator both are hot.
Upper one got hot quicker that lower one. Is that simptoms the termostat and fan clutch problems or something else? Thank in advance.
