Results 1 to 10 of 15
Thread: Dyno numbers
    Thanks again for setting up the dyno day.
    Numbers are very relative & we took a small sampling. Adjusting for correct air fuel ratio along the rev range, improved power everywhere. This was an increase from the proper tuning of the MAF 4 pot controller with the dyno meter & its wide band air fuel sensor. I was earlier rich at idle & lean at power, nowhere near ideal. I am very happy with the MAF, now that it has been properly tuned with the dyno's wide band air fuel sensor along the entire range of rpm's.
    Buy Bruno's MAF, it is good.
    erased due to slander
    What'd the beast turn Baconator?
    Bellevue WA
    86 Porsche 951 - Track Toy
    Default It showed about half the torque of a couple seperate mustangs.
    The lower curve is a previous run while dialing in the MAF. I must epoxy the front of the maf controller together, to seize the adjusters into place. No more fudgin' with that bastard!
    The dyno operator pulled up the air/fuel ratio screen & helped dial the MAF. 5 or 6 runs was all it took to get the thing into a consistent, narrow mixture thoughout the rev range.
    Quote Originally Posted by Jeff N.
    in a sexy house
    Default Nice numbers and sweet curves Martin--
    Pretty impressive what the M30 puts out for nice, flat, low end torque when it's getting fed a good diet!
    uh oh....i think i know what this means.....
    Bellevue WA
    Canada, ON
    Martin, you should upload the modified curve with a laptop... Then you can set up your pots at zero and dowload it back...
    Renton, WA
    Quote Originally Posted by Bruno
    Really, you can set a particular curve to be the baseline? That is damn cool.
    Now I REALLY have to buy one.
    1992 535i TCD-s2
    Canada, ON
    I am getting my car on the dyno after the larger throttle body next month, I will make a custom curve for the MAF.
  1. Anyone need a Dyno?
    By Felixdacat in forum 5 Series BMW
    Last Post: 03-04-2007, 07:08 PM
  2. Hartge dyno results, done a dyno test today on the e34 535i
    By Brent in NZ hartge 535i in forum 5 Series BMW
    Last Post: 02-06-2007, 05:50 AM
  3. 95 M3 Dyno Today
    Last Post: 07-07-2006, 01:33 AM
  4. I put my car on the dyno
    Last Post: 10-09-2005, 08:56 PM
  5. Anyone with dyno numbers, let see them
    By Craig in forum 5 Series BMW
    Last Post: 03-19-2004, 03:13 PM
