Results 1 to 4 of 4
Thread: belly plate off to change manual trans fluid?
    freezin ass cold WI formerly freezin ass cold MN
    Default belly plate off to change manual trans fluid?
    Do you have to take that whole thing off to get to the transmission? thanks
    95 540 six speed, Rondell 58 wheels, nothin else special
    79 911 SC - pea soup green
    Kingston, Ontario, Canada
    No, Scott. But you will need one of those suction pumps to do it. The fill and drain plugs are a few inches apart, one slightly higher than the other, on the left forward side of the 6-sp.
    Cheers,
    Duey
    1995 540i/6 Sport Pkg w/E.A.T. chip and Nikasil injection Duey's Gallery
    Thanks Duey. I was looking for the 17mm hex sockets that Bentley shows. Glad I spent the afternoon looking for one. I'll be returning that later in the week. Plugs were in so tight I had to use my foot to loosen them. I just used a tube that attaches to the mobil 1 bottle and squeezed real hard. worked. Made only a little mess relative to some of my bigger messes
    The first time I changed the fluid, I found the drain right away but couldn't find the fill (although I was staring right at it ) Mine were tight as well.
    I find the bonus to the suction pump is the ability to also clear all the old oil out of the bottom of the filter cannister/holder that doesn't otherwise drain out.
    Cheers,
    Duey
  1. Manual trans fluid?
    By rockitansky6831 in forum 5 Series BMW
    Last Post: 08-22-2008, 04:22 PM
  2. trans fluid change-build your own pump
    Last Post: 12-02-2005, 10:40 AM
  3. Best Manual Trans Fluid?
    By freeparking in forum 5 Series BMW
    Last Post: 10-17-2005, 04:48 PM
  4. Trans. Fluid Change questions, A4S310R....
    By MO525 in forum 5 Series BMW
    Last Post: 04-11-2004, 06:51 AM
