Results 1 to 7 of 7
Thread: Any new solutions to an old problem?
    Aug 2006
    Europe
    Default Any new solutions to an old problem?
    My dip beams won't work. I know... the relays in the LKM need to be re-soldered and the joints checked.
    This I've done but my headlights still don't work.
    A silly question perhaps, but do LKMs fail?
    All other lights work fine and no error messages are reported by the Check Engine light strip.
    Does anyone have any ideas that will let me see the light?
    Wellington,New Zealand
    have you got power at the fuses,there are at least three?
    Gone but not forgotten
    Aug 2006
    Europe
    I checked fuses 2, 10 and 11, lights off and lights (theoretically) on.
    2's fine anyway given that it's necessary for high-beam too and my high-beams work.
    10 and 11 (left and right low beams respectively) return 9.62V regardless if the headlights are switched on or off.
    I realise that according to info I've read that this value is more or less normal when the lights are off. But obviously 12V should be feeding through when on.
    Is it a matter of a kaputt LKM?
    Your photo is almost cruel, brazenly showing off the luxury of functioning low-beams! ;-)
    Aug 2006
    Europe
    Should it be a case of LKM replacement, does anyone know how interchangable these units are?
    Mine is a LKM (B) 61.35-1 379 372
    but some 64.35-8 350 375 or 62.35-1 379 371 models are available on-line.
    Any good?
    Default Are the bulbs good?
    I once had 2 bulbs go at the same time, I was convinced it was the switch. Many hours later I checked the bulbs. Just a stupid question.
    Warren
    88 325iX
    91 318is
    95 525iT
    Sep 2006
    Arizona
    Quote Originally Posted by Eric540i
    Any good?
    I take it your talking about the Single and double board LKM. You can run them with out any problems.
    Aug 2006
    Europe
    A fair question.
    But I checked the bulbs, and even tried a spare set I have, but I'm still left in the dark.
  1. car won't start in winter? symptoms/solutions
    Last Post: 01-01-2010, 06:08 PM
  2. Replies: 4
    Last Post: 01-10-2009, 01:40 PM
  3. Ignition problem or fuel problem?
    By xtmsports in forum 5 Series BMW
    Last Post: 03-22-2005, 07:30 AM
  4. Solutions for false "Washer fluid Low" error?
    By Mitch90535im in forum 5 Series BMW
    Last Post: 05-12-2004, 10:36 PM
