I have read that its really hard to cut glass by hand with out creating waviness.
Can polishing compound cut glass? I have glass stripper but I want something more powerful to use and then use the stripper followed by... (Do you think swirl remover would polish glass also?
Your ideas, I got acidon my windows and I want to get rid of the marks. I went over everything w glass stripper with a buffer once but It needs to cut it down a bit more to completely remove it.
EuroLux:. Private Detail
Maybe one of those guys who repair rock chips and such could polish it for you. They do some pretty amazing stuff.
Talk to some windshield repair guys, I'm sure they might have some advice for you
1990 Islandgrun 535iM Sedan
3k oil changes | Euro lights + trim | Eibach/Bilstein | EAT Chip
Unless something new has come around, the way we used to always polish glass was with a special dense felt round block spinning at low rotational speeds with a fine white compound especially made for glass surfaces.
Heat will break the outer layer of glass if your not careful about speeds and pressure.
It is limited however, to the REAL amount of scratches and etching that can be removed.
It will indeed brighten the dull,hazy appearence of an old windshield.
You MUST overlap consistantly and do the WHOLE surface for it to look right when you stand back and observe .....or it will be spotty.![]()
Even the Pro's have to DEAL with the hassle of it !
.........Vinny
AC Schnitzer | S-5 | Stainless exhaust | Bodykit | wing| 3pc. wheels | badges | springs | mirrors | steerwheel |
Schwarz on Blk
