Results 1 to 4 of 4
Thread: rough idle/no power -M70 - basics to check
    Default rough idle/no power -M70 - basics to check
    In case plug lead 6 or 12 (the ones with the inductive pickup donuts on them) are disconnected or short, a protection circuit embedded within the Motronic will severely clip the duty cycle of the injectors for that side to protect the catalysts from being drenched in raw, unburned fuel.
    Catalytic converter protection function
    Ignition circuit monitoring
    The ignition circuit is monitored by the cylinder detection sender (pin 16) on ignition line 6 (or 12). If it detects no ignition signal on ignition line 6 (or 12) , the fuel supply to to the relevant cylinder bank is cut out by shortening the injection signal. The sender monitors the entire primary side of ignition, and cylinder 6 or 12 on the secondary side.
    The inductive sensor is outlined in red above.
    http://www.fibersonde.com/e31/images...catprotect.jpg
    The above was from roadfly E31 board, and the MOTRONIC was 1.7 M70.
    Now we just tried:
    results of test (simple)
    Shogun's 1988/89 750iL (11/88, MOTRONIC version 1.2)
    well we disconnected the passenger side cylinder ID plug at front of engine.
    key to position 2, EML light comes on, after a few seconds off.
    engine start, runs on only 6 cylinders and rough -- NO EML or other warning!
    Accelerator used, still no warning.
    Reconnected and restart -- all 12 running, no warning.
    Disconnected both cylinder ID plugs.
    same result -- engine runs but only 6.
    Used Peake Fault Code reader and found no fault codes related to engine --ummm
    Reconnected and runs like a champ. Still no warnings.
    I thought the engine would stop with both disconnected but no true.
    Over to you guys
    more info with pics https://www.bmw-rudel.de/index.php/b...en-und-aktoren
    shows cylinder nos, CPS, donuts, temperature sensors locations and Ohms, plug locations of CPS and dounts
    explosion drawing M70 engine, https://www.7-forum.com/bild.php?bil...%20und%20sport
  1. rough idle... again...
    By pong in forum 5 Series BMW
    Last Post: 08-22-2007, 05:30 PM
  2. very rough idle
    Last Post: 04-29-2007, 10:10 PM
  3. M70 rough idle/no power - how to check
    Last Post: 08-29-2006, 11:48 PM
  4. "Check Engine" rough idle after engine Shampoo??
    By Guelphguy in forum 5 Series BMW
    Last Post: 04-27-2006, 01:06 PM
  5. Replies: 7
    Last Post: 03-09-2005, 10:42 AM
