Results 1 to 7 of 7
Thread: Bavarian Autosport High Performance Ignition Wire Set
    Barrie Ontario, Canada
    Default Bavarian Autosport High Performance Ignition Wire Set
    Anyone tried these bad boys, im replacing my wires anyway so i caught this in the holiday email from bavarian auto.. anyone tried? heard anythign bout these?
    "Loosen the reins on your thoroughbred with our 8 mm ignition wires. Stock Ignition wires have built-in resistors that reduce voltage to your spark plugs. That's like keeping a tight rein on a thoroughbred race horse -- it wants to run faster but can't. Our 8mm wires loosen those reins, providing the hotter spark your BMW craves. Both the wires and boots use a spiral core magnetic suppression conductor to provide a higher spark voltage for maximum combustion efficiency. And they're insulated with 8mm of pure silicon to completely eliminate interference. Lifetime warranty. "
    Cheers
    J.McWatters
    lol... you dont need "high performance" anything on your already high performance engine (in comparison to American metal)
    They are missing the covers.
    Being directly above the exhaust manifolds in a tight spot, I am sure these help to avoid physical damage to the wires when removing and replacing the plugs. The stocks ones are very nicely made. These don't look as good, but that's by me going off your pic... I really can't tell for sure.
    most aftermarket crap I have had experience with tends to weld the connectors to the plugs and result in a pulled connector off the wire rendering them junk any time you want to check or replace plugs...
    Yea, even with an upgraded coil (if I do) I't'd take a lot to get me away from the stock leads...
    USA
    you would be better off with stock wires and high grade spark plugs.
    i would be interested in seeing EM readings from stock and "spiral core magnetic suppression conductor" cables however, for intellectual curiosity. cables that emit less EM interference also absorb less, and would produce a more stable current.
  1. Ot: bavarian autosport
    Last Post: 06-30-2007, 09:25 PM
  2. Replies: 16
    Last Post: 11-15-2006, 05:11 AM
  3. Replies: 1
    Last Post: 03-25-2006, 11:34 PM
  4. High Performance Ignition coils.
    By granit_silber in forum 5 Series BMW
    Last Post: 09-26-2005, 01:01 AM
  5. Bavarian Autosport High Performance Coils?
    Last Post: 08-31-2005, 02:43 PM
