Thread: 540i error
    Nov 2006
    central coast nsw
    Default 540i error
    i have a 94 540i and once i turn the headlights on i get a brake light error message.it then cycles thru saying dim light/number plate light etc r faulty.
    have had an auto electrian check globes,earths etc and they can't find anything wrong.no prblems in day running only starts when headlights on
    hope someone can give us an idea
    Is the brake light off then when you get the warning?
    Derbyshire, UK
    Assuming all the wiring and contacts are good, and you have proper bulbs, it might be a failure of the light control module (LKM) or the check control module (CCM).
    1997 535i V8
    Nov 2006
    central coast nsw
    most usally starts when i brake with headlights on
    Nov 2006
    central coast nsw
    Quote Originally Posted by DaveVoorhis
    thanks am starting to think must be sum computer module problem.guess it will b an expensive bmw dealer job
    rgds,
    geoff
    Quote Originally Posted by compmore
    thanks am starting to think must be sum computer module problem.guess it will b an expensive bmw dealer job rgds, geoff
    Mostly its not, the modules unplug and when you open them up they often reveal dry or damaged joints where relay pins are soldered. The occasinal module failiure happens, but its usually the years of use/heat the relays see that things go wrong. Just pull them and check them. plenty of info online about the LKM nad mustard relay repairs.
  1. Carsoft error help please
    By ss2115 in forum 5 Series BMW
    Last Post: 10-27-2009, 04:51 AM
  2. Low beam error won't go away
    By shanek in forum 5 Series BMW
    Last Post: 04-02-2008, 10:31 AM
  3. Odd error
    Last Post: 07-17-2007, 08:09 AM
  4. Error Codes / Stomp TEst 540i 1994
    By Evan in forum 5 Series BMW
    Last Post: 09-28-2006, 12:04 PM
  5. M50 strange error
    By grave77 in forum 5 Series BMW
    Last Post: 02-09-2006, 02:45 PM
