the timer on most cars is just that,a timer.Some cars have the "parked ventilation" feature.
How does the auxiliar ventilation work s??
I press the timer button , and the display start to counter (01 , 02 .....)
If i want to retrofit an Webasto , what shoud i need ???
Thanks
525 i , e34 , m50 engine
Vadim,
I assume you talk about the optional item parking ventilation.
That will not help you in Rumania where it is probably very cold. It is just for summer time to ventilate the car for up to 30 minutes.
A WEBASTO is a heating system, as you probably want to buy for heating the cabin and maybe also pre-heating the engine coolant.
The Webasto consumes about 1.3 Liter poer hour of fuel.
But I am afraid that the complete system is pretty expensive.
Here some general info
http://www.webasto.com.au/am/en/am_a...ters_3354.html
http://www.wohlfuehlklima.de/download/en/webasto_car_2004_en.pdf#search='webasto%20car%20he ater'
In need this feature because in Romania it is hot an cold (in may to the firs part of september are 35 to 45 c ; and from september to april are from -15 to 10 c)Originally Posted by shogun
Do you know where it must be located the webasto computer ...... ??
Thank s
Can I retrofit the "parked ventilation " ??Originally Posted by Paul in NZ
Thanks
o.k., here is how the ventilation works and how to install one, that was optional item
http://www.bmwe34.net/e34main/upgrade/ventilation.htm
thanksOriginally Posted by shogun
