Results 1 to 10 of 13
Thread: ever seen this on your check control?
    Default ever seen this on your check control?
    What shall I do now?
    Can I drive home with that indication?
    ~30 Miles North of Chicago, Illinois
    hahaha
    [1994 530i/5-Speed]
    aftermarket chip?
    1995 525i
    Clear Corners
    New Hellas
    BAVauto Performance ignition coils
    Jan 2005
    Thats funny.
    95 E34 540i6 M Sport - 94 E34 530iT B40/6 - 92 E34 525i5 M52/OBD2 rip
    Quote Originally Posted by bmwalfa
    aftermarket chip?
    haha, no it's edited, you can see where DIST used to be
    [1994 530i/5-Speed]
    Hey Fetch,
    do not give the true answer so early
    Found this on a U.K. E32 board
    you sly cat.
    what are the green lights below "distaster" i couldnt figure this out on my e34.
    1995 525i
    Clear Corners
    New Hellas
    Hey Fetch,
    haha....you're right though, I shouldn't have spoiled it so soon!
    [1994 530i/5-Speed]
    you sly cat.
    Those are called the 'service indicators', search on the forum, you'll find tons of info
    [1994 530i/5-Speed]
    you sly cat.
    Oil service interval, see owners manual.
    To reset the service indicator after performing an oil-service or an inspection:
    1. With the ignition off connect pin 7 (SI reset) with pin 19 (gnd). Remeber to fuse this wire or to use a resistor just to be safe.
    2. Turn the ignition to position 2.
    3. Pull the wire out after about 5 seconds to get an oil reset or 10 seconds for an inspection reset.
    3. Now replace the cap on the diagnostic connector.
    4. Turn off the ignition.
  1. Check Control
    By bad2buck in forum 5 Series BMW
    Last Post: 01-14-2009, 03:08 PM
  2. Check Control....
    By bmwrp8 in forum 5 Series BMW
    Last Post: 10-02-2007, 11:08 PM
  3. Check control
    Last Post: 03-10-2006, 03:47 PM
  4. check control
    By stx133 in forum 5 Series BMW
    Last Post: 02-05-2006, 11:17 PM
  5. Check Control etc...
    By Fergi in forum 5 Series BMW
    Last Post: 04-28-2004, 12:42 PM
