Results 1 to 10 of 17
Thread: How to make a fan clutch remover tool
    Norcross, GA
    Default How to make a fan clutch remover tool
    I know this has been discussed a lot of times. I am a dumb person, I need more like a step by step instruction.
    what kind of steel plate to buy and where?
    What size should be the hole?
    How to make the curve?
    Thanks
    Arun
    530i / Nikasil M60 3 Ltr Motor / ZF5HP18 (A5S 310Z) Tranny / Prod: March 95 / Fully stock / 95K miles
    Honolulu
    Default I've been planning
    on making one out of aluminum.
    I’d start with the hole and shape it from there.
    I think Jeff made an Ork sword once and posted a picture
    Aug 2006
    Houston
    I am puzzled by the shape of it, where do you put this in order to get the fan clutch off? I am gonna be replacing mine some time soon myself
    the hole goes over a bolt and holds it still while you unscrew the clutch. I tried vice grips at first only to discover the pully is plastic :eek:
    Quote Originally Posted by Milkboot
    I made mine about twice as long as Jeff's tool in order to have more leverage. Mine actually is long enough to be butted up against the side of the engine bay by the power steering lines. This way you can loosen the more stubborn ones with both hands (mine was apparently tightened by five greasemonkeys high on crack). I also chose to make two holes on the sides of the cutout instead of just a notch like Jeff's. For a material I just used a thick 2" wide steel strip from Home Depot (look for it next to the assorted nuts and bolts section). 20 minutes later I had a tool HTH
    Sep 2005
    NJ
    I made mine from a piece of scrap metal at my neighbors machine shop. I recessed the pulley bolts so it's easier to keep them in place.
    Calgary AB Canada
    Quote Originally Posted by E34 530
    Cripes! That's like using a sledge hammer to swat a mosquito.
    I've never needed anything more than a bit of impact to remove these on several cars: 3 times for cam belt changes on an M20 325iS, 535i twice, M5 once each on two different cars.
    10" vise grips clamped firmly on the nut then a couple of smart taps with a hammer. Apply the pliers so the setscrew is on the side you need to strike for the left hand thread to loosen.
    Anthony
    03/64 production
    just wait till you get one that a ******* worked on, i had one on a 535 that was so bad i had to pull the water pump (was bad anyway) and break it up so i could clamp the shaft in a vice, i broke the box end on a 32mm wrench beating it with a brass hammer trying to save the fairly new clutch on that one
    heres one that i made a while back
    my current one is longer, i plan to make it double ended with the 6 cylinder spacing on one end the the v8 on the other
    Quote Originally Posted by Anthony (M5 in Calgary)
    Aug 2006
    Houston
    I might be able to find some scrap metal to make one, what is te best way to measure out the bolt hole distance so i can drill tem out, and ow far in should i make the most inner part of the curved part to get around the clutch nut?
  1. Fan clutch tool help:
    By E34 530 in forum 5 Series BMW
    Last Post: 08-27-2012, 06:21 AM
  2. DIY fan clutch tool
    Last Post: 06-24-2011, 09:24 PM
  3. Ignition lock cylinder removal tool make?
    Last Post: 02-09-2008, 08:25 PM
  4. BMW Fan Clutch Tool
    By granit_silber in forum 5 Series BMW
    Last Post: 10-10-2005, 06:07 PM
  5. Does fan clutch removal require a special tool?
    By mancini_mark in forum 5 Series BMW
    Last Post: 06-21-2004, 03:19 PM
