A huh? I had a clever witty remark all written out and its gone?![]()
1995 540i Manual build 1/95
lacquer thinner, unless you have fresh paint
Wow.. thanks ,no its eleven year old original Oxfordgrüen 324Originally Posted by Ross
Depends on what you're trying to get the overspray off. If it's your paintwork, use a claybar kit. If it's your windshield, you'll have to determine what the paint was thinned with, either reducer or laquer thinner, and use that to remove the overspray.
Off my Paint on the roof.. Thanks. I had lost hope and consigned myself to loooking like i drove under Mt. Pinatubo..Originally Posted by Jr ///M5
Go to your local autoparts store (not stoned) and buy a claybar kit. Mothers makes a good one.
Wash the car throughly, use a potato chip size piece of the clay and plenty of the lubricant that comes in the kit. Rub in the same direction and if you drop the clay, throw it away. You will see the embedded dirt that was in your paint load up on the clay. Replace the clay when it becomes contaminated. Wash the residue off of the car and dry it throughly. Polish it with your favorite polish and after it's all shiny, wax it to protect it. You won't believe how slick the finish will be. Bugs will fall to their death after alighting on your car.
2nd the clay. A full treatment fixes anything.
yep clay kicks ass, it's a step beyond a polishing but a step under a severe compounding, it's almost impossible to hurt paint with clay
If you try to buff the panel without removing the debris with a claybar, you'll end up with deep swirls that you cannot get out. Some waxes will cover up the swirls by using fillers, but the swirls will always return. That's why you polish using a Porter Cable and pure polish after using the claybar. It helps to level the surface again making it more reflective and brings back that "wet" look. The wax helps to magnify the shine a little, but is more of a protective barrier than anything else.
plain mineral spirates man, wont damage the paint at all and will soften the fresher over spray enough to melt away into a rag. How did I figure this out? LOL
I never tried the claybar, sounds beyond my patience level.
