Results 1 to 9 of 9
Thread: 6 speed conversion...electrical
    East Brunswick, New Jersey
    Default 6 speed conversion...electrical
    I reconnected the battery positive cable in the rear seat after almost 6 months 30 minutes ago. The car started after cranking for about 15 seconds. There are a number of messages, oil level sensor, owner's manual, trans program and one or two more I can't remember. I had to shut it down when I saw smoke came out of the engine compartment on the passenger side. After I shut the engine off, the starter was still cranking. I was in a real panic. Dashed into the garage to get a 13 mm socket. Fumbling through the tool box. Why is it you never find what you are looking for when you are in a panic? Finally I did and dahsed back to the car in the driveway to disconnect the batter cable after what seemed like eternity.
    After I reconnected the battery the starter won't turn any more. I may have fried the starter. But I kind of doubt it. Because it was still turning when I disconnected the battery.
    When I opened the hood to look into the passenger side. I saw this. One of the ground wires was burnt. I wasn't sure that's where it should be. Could someone who has a 540 take a picture of that area for me?
    On the shifter this is what I did.
    I jumpered the green/red wire from fuse F17 (7.5A) to the brown/black wire at the auto transmission range connector so the starter immobilizer relay is energized when I turned the ignition key to start the car. The two yellow connectors are from the back-up light switch. There is not a separate back-up light switch on the auto transmission but one on the 6 speed. I used a generic Bosch two wire connector to connect to the auto transmission range connector.
    Even if I fix this eventually I still need to corrct the trans program message. The other messages are probably minor.
    What did I do wrong?
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    Can someone who has either a 530 or a 540 take a picture of the jump start connector on paasenger side of the engine compartment for me? I must have screwed up the wiring placement by fastening the two black wires on the same ground nut.
    before,
    after, the wire is burnt,
    '01 540it, 6/01
    '10 535ix. 9/09
    '10 mini 6 speed
    Long Island, NY
    I'll do it when I get home. I would have tried to get it last night but it was raining cats and dogs in Jersey yesterday.
    '94 540I 6spd/205000 miles
    Nov 2004
    Winston-Salem, NC
    I am assuming that you're converting the 540iA to an iM and not changing out the 5-sp in your 525 for a 6-spd. If that's the case I understand that the only way to get rid of the TransProgram message is to install an ECU from a 6 speed 540.
    -ashley
    Paper Gaskets Suck!
    It is not poosible to change my 525 5 speed to a 6 speed. The bolt patter and form are different. As to the trans program message, I was advised differently. But I am not at that point yet. Need to sort out the wiring issue first and get the car started again. I do hope the starter is not fried because of continued cranking.
    '01 540it, 6/01
    '10 535ix. 9/09
    '10 mini 6 speed
    Nov 2004
    Winston-Salem, NC
    Quote Originally Posted by yaofeng
    Yeah, I was a little confused and just making sure. Although I guess I would figured it out if I had read your sig.
    -ashley
    Paper Gaskets Suck!
    Quote Originally Posted by bbig119
    Thanks. Someone on another board provided the picture and answer.
    http://www.bimmerboard.com/forums/posts/276563
    The burnt wire should have been connected to the positive lead. I had it on the ground nut. I think it explained why the starter kept cranking when I shut the engine off. The current load on the starter is more than that wire can take that is why it was smoking.
    '01 540it, 6/01
    '10 535ix. 9/09
    '10 mini 6 speed
    Long Island, NY
    I hope that simple switch is all it takes to get your car running. Sorry I didn't get you the pictures sooner.
    So you bought the 540 Steve Petry converted to 6 speed? I talked to him this afternoon thanks to the contact info you provided a few months ago. Steve drove the 540 with the trans prog after conversion. He said you found the solution to disabled the message. I'll be tackling that if and when I restart the car.
    '01 540it, 6/01
    '10 535ix. 9/09
    '10 mini 6 speed
  1. 5-speed conversion
    By specialguess in forum 5 Series BMW
    Last Post: 10-12-2008, 02:43 PM
  2. 5-speed conversion
    Last Post: 05-11-2007, 10:09 AM
  3. 540 6 speed conversion, electrical fiasco
    Last Post: 03-11-2007, 05:28 PM
  4. Anyone do a E34 5 speed conversion?
    By dave_in_va in forum 5 Series BMW
    Last Post: 04-01-2006, 11:49 AM
  5. Replies: 17
    Last Post: 10-24-2005, 11:02 AM
