fall asleep?
Okay, before pictures of the lows and highs.
fall asleep?
Sorry, should have been clearer.Originally Posted by 632 Regal
Headlights are at my parent's place, went down for the weekend. I'll be back down there next weekend, as I need to replace the radiator and waterpump on my 540i... too much play on the fan, and the rad sprung a leak from the side plastic resevoir.Gonna pick up my refinished wheels tho, so that's a big plus
I painted the headlights, we'll see how they look dry, and I'll probably wet sand/polish them to get a smooth texture... they were a bit rippley when I left.
I had to use a pretty wet coat for them to lay down smooth, know what you mean by ripply. Kept re-doing them til I got a decent wet coat. Did you notice a lot of small air bubbles in yours? The spray nozzle on the can I got has a lot to be desired.
Originally Posted by TC535i
Yea, the bubbles worked themselves out. I noticed that when I sprayed too lightly, it left much more texture. I started laying them heavy towards the end, and they laid down smoother.
I'll call my parents tomorrow and see what my dad thinks they look like fully dried... but I'm expecting to have to sand/polish a bit.
I did 3 coats for a durable coating but the bubbles were consuming and I stopped. To think a large rock would have been stopped was nieve...I wonder now if I had left them that rock would have missed my newly transpires lenses...sigh. Ahh well tape is good too. Was thinking about this hot plastic glue gun... As for polishing remember this is a soft plastic type of paint, rubbery so it might not sand/buff in normal matter.
would/could/should this work on plastic E46 headlights?
1995 525i "Stefanie"
Speaking of paint, we and a few other E34 people should get together and do this:Originally Posted by TC535i
http://www.bimmer.info/forum/showthread.php?t=26036
Cuse I would f it up doing it alone haha
bring it on over!
Originally Posted by BFEINZIMER
for plastic i use 1500grit with soapy waterOriginally Posted by mzarifkar
then high speed rotary polish with 3" buffer attached to my drill
with the plastic i find it better to remove material and get the dirt out of the crevices prior to polishing.
You could try a painted applique, but that would trap the dirt and not take away any yellowing.
I do this (plastic headlamp restoration) as a side gig. Its pretty good as the overhead isn't high at all and I usually charge about $50, $75w/ new bulbs installed. My customers love it (seeing at night, that is)
