Originally Posted by
sbcncsu
Yes, it is very replaceable. Only problem is you have to drill out the rivets that BMW used to attach the regulator to the door to remove the regulator. You must remove the regulator to get to the bolts that hold the motor to the regulator. (All of this is outlined in the Bentley manual.) I did it on my old 95 525ia driver's door. It was an afternoon job, not too bad.
On the old forum, there were pictures provided by one of the regulars, Gordon I think. It showed the procedure pretty explicitly.
Also, the regulator in the BMW is not spring loaded and the windows aren't so big that you lose control over them when you disconnect the regulator from the window.
