Originally Posted by
nicholas.solutions
I have just swapped out the engine and auto tranny in my '91 e34. The TCM (trans control module) that came with the tranny keeps the car in limp mode. It came out of a '95 e34. When I use the original TCM the car goes into limp mode when I kick down into a passing gear above about 20mph. Can either of the TCM's be reprogrammed to work properly with my new configuration? I have checked all fuses under rear seat and found no problems there. Any help would be apreciated.
-Nicholas
Also, I need to replace the drivers side strut assembly. Is this a fairly straight-forward procedure or does it require special tools and expertise.
