haha thats awesome fetch, i would love to see somebody do that.... as long as they didnt get smashed to bits.
the only way you would want to do the shake test on an M60 engine automatic is by putting it on a dyno.
there is a technical service bulletin in regards to failing valve bodies in the transmission, as they attempt to compensate for something that isnt going to happen (since the car is in neutral)
and dont jack the car up and run it like that, as its very bad for the rear CV joints, and the change in rotating mass can cause the car to push the jacks around.
