Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: 540i Engine Shudder/Vibrations
  1. #21
    Jul 2005
    North SF bay area Delta region
    Quote Originally Posted by stargazer_61
    If you want to see if the engine mounts are broken, try this:
    1) Start the car & set the hand brake and let it warm up.
    2) Open the hood
    3) Find the throttle cable & push/pull it to rev the engine. Don't be shy about revving it hard.
    If the engine mounts are shot, the engine will lift up on the left side at least an inch. It is not easy to tell if the mounts are shot simply by looking at them. On a LHD car, the driver side mount is buried underneath oil & power steering lines and is difficult to look at.
    We would check for bad motor mounts by;
    Giving the car some gas while it's in gear with your foot on the brakes. No need to Rev motor up.
    The motors torque will lift the motor right off the bad mount.
    1991 525i M50 5 Sp.
    N.California
  2. #22
    Dec 2006
    Adelaide Hills
    aaaaaactually ...... revving in Park or Neutral won't have any effect on the trans as the only thing spinning is the gearbox input shaft, no load on the gears at all (Park locks the output shaft). You need to load the drive train, so with the trans in Drive but foot firmly on the foot brake and handbrake on, give the throttle a few sharp blips - no Italian tune-up style hit-the-rev-limiter mashing of the foot to the firewall - and have your friend (who shall be standing beside, not in front, of the car) watch for excessive movement in the engine ..... sheesh, you guys!
    June 88 535iA, 173,000 km; Sep 00 735i 170,000 km
  3. #23
    May 2006
    Antwerp, Belgium
    Hmm. Is it really an inch? I think I get about an inch of movement just by revving my M50 in neutral on the manual trans. Could be the motor mounts are kinda shot but it's not that big a deal vibration-wise.
    2008 audi A3 1.9tdi
    (former 1991 520i LPG)
  4. #24
    aaaaaaaaaaactually the auto transmisions can and do fry with free reving due to the spinning drum (& clutch packs) as I mentioned earlier.
    Quote Originally Posted by Podmore
  1. wheel shudder
    By Paul in NZ in forum 5 Series BMW
    Last Post: 02-25-2008, 04:13 PM
  2. Shudder on shut-off
    By Tom Bombadil in forum 5 Series BMW
    Last Post: 07-08-2006, 04:25 PM
  3. Shudder/Grinding
    Last Post: 02-19-2006, 01:10 PM
  4. Shudder during reverse
    By Ken in Australia in forum 5 Series BMW
    Last Post: 11-23-2005, 06:57 PM
  5. engine vibrations when in Park
    By 94bmw540i in forum 5 Series BMW
    Last Post: 08-09-2004, 03:17 PM
