Results 1 to 10 of 43
Thread: oh computer guys, mine is pissing me off
    it spools and when connected to the raid controler (the first port i plugged into) i can look at the drive and play with raid info if i ctrl-F pre boot which is the only place the drive is visible, but since i switched to the (supposedly) correct port that's gone, from the crap i've read about it's probably going to be a bios/driver problem, common?! problem with this board maybe it wants me to buy 3 more drives and build a array, i need that like i need a sore cock
    Winfred - hold the drive in your hand with the power and SATA connected - do you feel/hear the drive spool up? I've received DOA drives before.
    Norcross, GA
    Hi Winfred,
    I think the raid controller bios & driver are hiding the drive. You can disable the raid configuration in the main BIOS. Go to the Main bios (press F2 or DEL) and there should be a place where you can configure the IDE controllers
    SATA controller has three modes of operation
    1. IDE mode - no AHCI, no RAID
    2. SATA mode (sometimes called AHCI mode) - AHCI enabled, no RAID
    3. RAID mode - AHCI enabled, RAID enabled
    I think yours is in (3) Raid mode. Ideal place is to put it in (2) SATA mode / AHCI mode. Try (1) only if (2) does not work
    Let me know what happens.
    Hope this helps
    Arun
    530i / Nikasil M60 3 Ltr Motor / ZF5HP18 (A5S 310Z) Tranny / Prod: March 95 / Fully stock / 95K miles
    Benneton (United Colors of)
    damn, the adaptors are cheap, though
    http://www.geeks.com/details.asp?inv...-20330&cpc=SCH
    11.99+8~$20 if you get really stuck.
    then again, i've never had a computer hardware problem that i haven't been able to fix with drivers (unless the thing is physically broken). any adaptor you buy isn't going to have the greatest driver support in the world (unless you buy something expensive), so you might just end up buying something that won't even work on your computer.
    ill check it out when i get home tonight, i am sure it's a solvable problem as others have gotten them to work, like i said why is my **** always retarded
    PA
    it's probably your diet
    meat cheese and taters with the occaisional green thing
    Norcross, GA
    Any luck after changing the BIOS settings?
    Arun
    nope dicked with it several hours last night and the drive is still invisable, still researching
    Quote Originally Posted by Alpinewhite
    Arun
  1. Replies: 30
    Last Post: 04-02-2005, 11:56 PM
  2. OT: For Canadian guys. Good friend of mine ...
    By Javier in forum 5 Series BMW
    Last Post: 03-20-2005, 09:39 PM
  3. Replies: 1
    Last Post: 01-11-2005, 04:43 PM
  4. Replies: 7
    Last Post: 12-31-2004, 07:49 PM
  5. K Guys way OT computer help...
    Last Post: 11-18-2004, 08:41 PM
