if you only pulled the lower hose there would be a buttload left in the engine. no clue how much.
jeff
that would explain the lack of room for extra water/ coolant.
id drain from the bottom hose again and add the antifreeze straight first then top with water. might be worth getting the block plug out if there isnt room for a 50/50 mix.
Hi
I think i will do it again, once i had drained it from the bottom hose i thought it was empty, then i poured in 6 litres of antifreeze straight, i was going to add more water as required. i will attempt the job again, now that i have the knowledge to do it properly.
Thanks
