Results 1 to 8 of 8
Thread: 1992 535I windows do not work when cold!
    Default 1992 535I windows do not work when cold!
    I have a 1992 535i, when it is cold outside the power windows, sunroof, and windsheild wipers do not work. Any help would be appreciated.
    Remove the door panels and grease the big gear
    http://www.autohausaz.com/secure/Par...1321944070.jpg
    as well as all parts which are moving.
    Clean the part where the window regulator bushings are running. Maybe full of dirt.
    All what you mentioned is controlled by the GM, but the GM can only handle max. 30 or 35 AMP.
    Is that is exceeded, it will switch off the function.
    Pull the GM, look for oxidized pins. If they are oxidized, clean them with a wire brush.
    From the GM the signal goes to the RM where the relays are inside.
    Ann Arbor Michigan
    I had a different thought on the subject.. perhaps the fusible link is cracked and is shrinking from the cold.
    The accessories that don’t work are in the same group that typically will fail when the fusible link is blown or cracked.
    Just a thought.
    SOLD!
    Quote Originally Posted by fujioko
    Just a thought.
    Thanks I will check these this weekend!!!
    Jul 2004
    Perth, Western Australia
    Default Fusible Link!!!!!!!
    I had EXACTLY the same symptoms not even a week ago, my 80mah fusible link had a crack right through the middle, when i touched it with my key it crumbled. Cost me AUD 2.00 and took less than a minute to install!!
    $2.00 and 1 minute? Took me longer to solder the connections (at least 5 mins) but it really needs to be riveted also.
    But my 80A link was not ideal- I got it from the dealer and it was old stock/corroded. In the end I replaced it when I installed a massive fuse block to run other devices. It also reads current draw and voltage, which is not necessary but handy. It takes 4 12mm glass fuses, but I had to use 2x40A ones as I cannot find an single 80A one of this type.
    However my parallel fuses are theoretically a bad idea (but they work so far, with lights and wipers- and power windows running). So I still I want an 80A one that I can heat shrink in there and rely upon. Where did you get yours, Mewsy? An auto shop? I tried Jaycar and Dick Smith without any luck... Cheers, Nick
    Jul 2004
    Default From the dealer...
    I bought the fuse straight from spare parts at Auto Calssic here in Perth. It was supposed to be about $2.50 but I didn't have the right change and I also had the Ambulance discount suit on!!
    My car is a 525i, so the fuse was right next to the battery under the bonnet, not the back seat. He said it was a common part replacement. My car has done 245,000km's so I don't know how long it has been in there - could have been ages
    Quote Originally Posted by genphreak
    Benneton (United Colors of)
    if the items you mention dont work in addition to the radio, blower, and locks, then the fusible link is the likely culprit. if your radio , blower and locks work (and not intermittently), its not the fusible link, its the GM/RM like shogun mentioned.
  1. new battery, and now rear windows don't work
    By quad in forum 5 Series BMW
    Last Post: 07-25-2006, 04:05 PM
  2. Rear Windows Don't Work
    By ProZak in forum 5 Series BMW
    Last Post: 06-10-2006, 05:57 PM
  3. Interior Lights Don't Work (1992 525 Wagon)
    By imnprsd in forum 5 Series BMW
    Last Post: 05-29-2006, 11:11 PM
  4. 1992 E34 weird idle in cold
    By jafcmi in forum 5 Series BMW
    Last Post: 12-13-2005, 08:15 AM
  5. Does auto-up only work on driver's windows
    By rnrn in forum 5 Series BMW
    Last Post: 08-03-2005, 07:50 PM
