Results 1 to 10 of 16
Thread: Cleaning electrical corrosion, or why I love Mormons.
    Aug 2006
    Bay Point Ca
    Default Cleaning electrical corrosion, or why I love Mormons.
    So I have had a serious fuel injection problem the last three weeks, as noted here. http://www.bimmer.info/forum/showthr...=fuel+injector
    Well, a day after I found the connector and found that I couldn't pop it loose, I broke my right pointer finger in the door of my wifes car. My wife is a Mormon. That's important in a minute.
    I can't work on my car at all. I broke the last bone in the finger tip and the risk of infection is very high, so no dirty work for me. Plus my finger guard gets caught on everything.
    Mormon Parisheners came by to see my wife, and she wasn't home. There whole thing is to help people, so when they asked me if I needed any help around the house, I let them go to town on my car. So now I have two young men in black slacks, white dress shirts and ties working on my car. Good times great memories.
    We (they) managed to pop it loose and I found that it was stuck closed because three of the seven pins are very corroded. Now, whats the best method to clean the pins and the connector? I know with a battery you use baking soda, water and a wire brush. Is this the same for here? Or will using water short something out?
    Cliffnotes - Mormons helped me do the hard work on my car, now how do I clean corrosion on a connector/harness?
    Aug 2006
    Boulder, CO, USA
    You can get a can of contact cleaner spray at the auto parts store. It has helped me a ton on salty connectors on my motorcycles. I'd avoid anything with water in it, as more water means more corrosion. Failing that, brake cleaner seems to work pretty well. Combine that with a wire brush or pipe cleaner. Let it dry and give it another try.
    baton rouge, loserana
    i came real close to driving over one once when he jerked infront of me on his bike, ****er would of been street pizza had i not seen him down the street and had been watching for exactly the stupid manuver he pulled
    Great Britain
    Oil and a brass wire brush would give the pins and sockets a good scrub. Clearly water is getting into the connector - you need to stop water from getting in. A good idea would be to pack the pins and sockets with petroleum jelly before re-assembly.
    I would use small metal brushes to get the corrosion off then use something like stabilant 22 to treat them all with. That stabilant 22 is magic.
    http://www.stabilant.com/
    Hockinson, Washington
    Quote Originally Posted by estrada42
    LOL! thats awesome! =D
    PA
    wtf Mormons?
    Jun 2006
    Frederick, MD
    I wanna know how you got the mormons clean.
    1990 535i
    117,000mi
    Feederick, MD
    If it has **** or tires, you are going to have problems.
    Aug 2006
    Bay Point Ca
    Well, I would have let them use my sink, but they refused to be a burden and pedaled there way off.
    I cleaned as much of the corrosion as I could, put some dieelectirc grease in the connector, and still no start on the car. Even re-charged the battery. Car just wont start now.
    You need to check resistance between both sides of that connector, I'll bet it's still the problem. Sorry about you finger, sounds painful.
  1. engine cleaning - no steam cleaning!
    Last Post: 03-09-2009, 08:23 AM
  2. I Love My E34!!!!!
    By Spasso in forum 5 Series BMW
    Last Post: 01-17-2007, 07:36 PM
  3. cylinder head corrosion - can it be fixed properly?
    By Randell in forum 5 Series BMW
    Last Post: 06-07-2006, 03:37 PM
  4. Thank you BMW - I love you too.
    Last Post: 05-12-2006, 10:28 AM
  5. Aluminum corrosion question
    Last Post: 07-18-2004, 05:03 PM
