Results 1 to 10 of 10
Thread: Headlight issues, help!
    Default Headlight issues, not LKM
    My passenger side headlight and driver side fog light is out. Bulbs are ok, I resoldered the relays in the LKM, I checked the fuses, and it STILL won't work.
    by the way, the passenger side parking light doesnt work, but the turn signal does. It's the same bulb. Fuses are ok.
    Parking light is controlled by the musrad relay, not the LKM.
    1. Do you have power at the headlights?
    2. Do you have power at the fuses even if the fuses seem to be o.k.?
    Get the multimeter and measure it.
    If there is no power at the fuses, then the LKM is still defective, because the relais inside the LKM have to close to get power to the fuses.
    It's your LKM. e34 dose not have a mustartd fuse, that is on e32.
    I have power at the headlights, but for some reason the terminal for the fuse has power, but when i put the fuse in, it has no power on the little points on the top of the fuse (not sure what they're called)
    I ordered a refurbed LKM, should be in by friday. until then I have ghetto-rigged it with a jumper wire just till I get it figured out. I can't go with just one headlight. (flame suit on)
    Aug 2004
    detroit
    yeah who the hell dose that kind of thing
    Quote Originally Posted by kyleN20
    its ok, she decided she didn't like that little jerry rig and spat it back out at me. blew a fuse on 94, no headlights....scared the crap outta me, had to drive with brights all the way home till i figured out what it was
    Aug 2004
    detroit
    i bet people loved that, those things are bright
    seriously, not a single person passed me without flashing. and it wasnt the good flashing, either. no boobies
    new used LKM, fixed the headlights! parking light still out, so is the fog light, but that is probably just a bulb, or maybe a wiring problem. either way, I can see to drive...here come the HID's!
  1. Replies: 16
    Last Post: 01-25-2008, 02:47 PM
  2. I need another 5er, which one????? Issues???
    By Messerschmitt in forum 5 Series BMW
    Last Post: 04-22-2006, 07:06 PM
  3. e30 issues
    By moots in forum 5 Series BMW
    Last Post: 12-07-2005, 02:08 AM
  4. Aux fan issues
    By Super90 in forum 5 Series BMW
    Last Post: 07-08-2004, 02:18 PM
