Check the voltage of the battery first. Maybe it is just a weak battery.
Today I replaced the starterd, and the car run for ten minutes then turn it off. I started the car and no problem. I let it run for ten to fifteen minutes then I turned the car off. Then when I tryed to run the car and it will not start again. Now only makes a clunk noise and the engine will not turn.
Can the starter stop working after two usage? The starter is a rebuild by Bosh. It is not new.
I need help
The battery is fine because I put on my other e34 and it works fine.
clunk?
never heard that, try hitting the starter with a wrench 3 times and trying again.
I am going to try to hit it, but it is going to be a little difficult because the starter is located under the intake.
