Results 1 to 9 of 9
Thread: It died and won't run
    Sep 2006
    Coarsegold CA
    Default It died and won't run
    I was driving, floored it, passing gear started to loose power, engine light came on. Won't run. Try's to start but won't run right.
    No noise.
    Stomp test = Oxygen sensor #1.
    Can that keep it from running?
    If that is it, where is Oxygen sensor #1 located?
    Thanks in advance.
    Don
    94 530it
    1994 530it 147,000
    1983 300SD 278,000 (running soybean oil)
    1980 300TD 135,000 (running soybean oil)
    Sep 2006
    Newnan
    hmm, dosent seem like that should kill it. If it is an o2 sensor just change them both. real easy if you rent an o2 sensor socket.
    sounds like more to it than an O2 sensor. Reboot the computer and then see if it runs. If so run til you get the cel light and recheck the code. Dont rush into replacing them yet.
    If it lost power during a romp it could very likly be fuel related such as pump/filter.
    USA
    if the fuel pump died while running hard, it would run on pure lean and the car would probably see that as the O2 sensor going off its rocker.
    Sep 2006
    Coarsegold CA
    Fuel is not the problem at least up to the rail. I checked it at the pump and the hose that connects to the rail.
    (rubbing head...taking Advil)
    Don
    1994 530it 147,000
    USA
    DME relay? (probably not if you get an O2 error)
    crank position sensor?
    Sep 2006
    Coarsegold CA
    I guess the first question I should ask is.....
    Are the codes specific and of value? OR Do you have to hunt down mechanical problems if and the codes are a guide.
    Don
    1994 530it 147,000
    USA
    the codes are just what the computer determines as wrong, if it throws a code for the air flow sensor, it could be a vacuum leak even with a perfectly working sensor. so..... its not extremely concise.
    the best bet is to fix all the obviously worn down parts and parts with questionable age.
    12 years on a car = things arent working the way they are supposed to.
    Sep 2006
    Coarsegold CA
    Quote Originally Posted by BillionPa
    To my surprise, there is so much plastic used under the hood, I don't know where to begin. I want it to be reliable and am willing to go through it and replace those items that given 12 years or heat need replacing, providing that is a financially reasonable approach.
    Don
    1994 530it 147,000
  1. Car Died. Diagnosis?
    By liquidtiger720 in forum 5 Series BMW
    Last Post: 10-11-2006, 09:21 PM
  2. Car died on way to work
    By av8r in forum 5 Series BMW
    Last Post: 09-27-2006, 09:29 AM
  3. Car Died then came Back?
    Last Post: 08-26-2006, 11:04 PM
  4. My E34 died tonight... :(
    By DanDombrowski in forum 5 Series BMW
    Last Post: 05-31-2006, 12:55 PM
  5. It Just Died....please help
    By Sailesh in forum 5 Series BMW
    Last Post: 08-08-2005, 09:30 AM
