Results 1 to 4 of 4
Thread: 94 525i won't start
    Nov 2004
    Default unlock OBC and get Battery Voltage
    did you check the battery? What's its voltage? Is it betwen 10.5v-11.5v (too low and needs replacing)...or is it higher (11.8v-12.5v)?
    Only asking because you said nothing about it. If you've unlocked your OBC...you can do a TEST #9 to get the battery voltage. If not, do you have a meter? If not, then remove it and take it to a place like Batteries Plus, or Autozone so they can load test it.
    If it is low...and you're at Autozone...just pick up a Duralast 49DL (usually for around $69)...if you're at Advance Auto pick up an Autocraft Titanium 49-1 (approx $59-$69)...if you're at Batteires Plus get a Werker 95R (approx $115).
    Instructions on how to unlock the OBC:
    To unlock OBC:
    • press 10 and 1000 ("Test" appears in the display)
    • enter 19 (press the 10 button once & the 1 button nine times) then press S/R button ("locked" appears in the display)
    • Now input the sum of the of the day and the month programmed in the OBC. (should be today's date... example: day 28 and month 10 equals 38). Using the 1000/100/10/1 buttons, press the 10 button 3 times and the 1 button 8 times.
    • press S/R (OBC unlocked)
    There are 20 test functions available on the OBC
    1. matrix display activation of LEDs
    2. AVG fuel consump. (car must be moving) liters per 100/Km
    3. AVG momentary fuel consump. liters per hour
    4. Fuel consump. for range AVG last 50 Km (dampened)
    5. Fuel consump. for range determined (not dampened)
    6. Present fuel amount liters (not dampened)
    7. Present fuel amount liters (dampened)
    8. Road speed from inst. cluster K.P.H.
    9. Battery voltage (w/engine NOT running...system(alternator) voltage with engine running)
    10. Sets reserve amount E-34 only
    11. Programming language E-34 only
    12. AVG speed for ARR time K.P.H.
    13. Arrival time undampened
    14. MFG date of ROM
    15. Fault memory for MFG purposes
    16. Check of inputs and out puts
    17. All data for OBC IV
    18. Horn sound for code alarm see note below
    19. Lock or Unlock
    20. Correction factor see note below
    Once the OBC is unlocked...at anytime you want to activate TEST program press the 10 and 1000 buttons... "TEST" appears in the display. Then using the 1000/100/10/1 buttons...enter the TEST # you want and press the S/R button. To leave the TEST features, press any of the OBC feature buttons.
    Q
    95 525iT / 97 740iL
    Sep 2006
    I took the battery to advance auto and it checked out ok. Sorry for not giving you that info. When I turn the key to start it, all the lights come on, but it won't do anything.
  1. 1995 E34 525i Still will not start
    By pcross in forum 5 Series BMW
    Last Post: 12-02-2008, 04:37 PM
  2. 1995 525i won't start
    Last Post: 11-17-2008, 07:11 PM
  3. 525I wont start
    By trentnwolf in forum 5 Series BMW
    Last Post: 03-26-2008, 04:15 PM
  4. 525i 94 e34 wont start
    By cj_bmw in forum 5 Series BMW
    Last Post: 12-03-2007, 09:21 PM
  5. E34 525i wont start
    By davidflrs in forum 5 Series BMW
    Last Post: 01-05-2005, 07:02 AM
