Results 1 to 10 of 17
Thread: What size fuel injectors are in the M60 530i?
    Sep 2006
    Newnan
    Default What size fuel injectors are in the M60 530i?
    ive looked everywhere and i cant find any info. I might be going with the ford bosch injectors so i would like to see what size i need?
    are they the same size as the 540i injectors?
    thanks
    1995 BMW 530ia/3.15lsd/M Parallels/Eibach/Bilstien/Magnaflow
    Default If you had done a search you would find that i have posted it many
    times in the past.
    Quote Originally Posted by Boone.Msi
    thanks
    Default From the sounds of your last post you still haven't changed the
    pcv plate and the intake manifold gaskets? if so ,this could be the cause of all your problems. Also have you done a compression check ? Is it a nikasil block?
    times in the past.
    Sep 2006
    Newnan
    yea i did a search i guess i just didnt put it in right cause i know i came across this before. correct, i have not done the pcv, o rings or gaskets yet. i just figured that i would find out what injectors they are in case when i pull the intake manifold they look gunked up.
    I have very little time on my hands so i doubt that i will even have this done untill monday. thanks for your help
    by the way, how the hell am i supposed to convers 4 milliliters an hour into x lbs. per hour?
    PA
    Huh? 440cc injectors are = 42#.... so 240 are prob 22# about. I bet its the same injector as on a '95 M3
    Nov 2004
    SF Bay Area
    Default Conversion to lb/hr (corrected)
    Sorry, I had this posted in error earlier. The following should be correct:
    Gasoline is about 0.68 gm/cc, so 240 cc/min is about 163 gm/min or about 9.8 kg/hr. At 2.2 lb/kg, this is about 21.6 lb/hr.
    Hal
    Sep 2006
    Newnan
    hmmm, what would you guys say to me getting the #19 injectors? would that make it too lean? Im heading to an all ford mustang salvage yard with a friend on monday for his car so i figured i would just get some injectors from there. are the #19's out of mustang gt's? what car should i pull from the GT or cobra?
    Honolulu
    Default take a look at this
    Check these guys out.
    http://www.fiveomotorsport.com/Injector_SetsBMW.asp
    You can cross the ford injectors with their tables.
    USA
    get the mean greenies.
    PA
    By green do you mean 42#? What the HELL is he going to do with 42# injectors.
  1. FPR/Fuel Injectors
    By nirvana19 in forum 5 Series BMW
    Last Post: 03-22-2009, 05:20 PM
  2. Would you recommend fuel injectors for my BMW? 19# ?
    By bissellh in forum 5 Series BMW
    Last Post: 12-31-2006, 10:41 PM
  3. Anyone have any use for 6 30#/hr fuel injectors?
    Last Post: 06-06-2006, 09:26 PM
  4. Fuel Injectors
    By Hector in forum 5 Series BMW
    Last Post: 08-03-2004, 01:45 PM
