Common problem - the low pressure return often leaks where it attaches to the reservoir. You probably just need to replace the hose clamp.
I'm getting some leaking from my power steering hoses. Seems to be from just under the reservoir. I'd like to order replacement hoses this morning, but I don't know if my new to me '94 530i has the rear leveling suspension or not. Is there an easy way to tell without getting under the car? If not, I can always wait to order the parts and check tonight.
www.universal5.com
Orange Tool Forum
San Diego, CA
1994 e34 530i Eibachs/KYB
0 miles on new windshield
I was just going to say this, double check this before getting new hoses I thinkOriginally Posted by pingu
[1994 530i/5-Speed]
I've checked that. The hose itself is actually crumbling a little above the hose clamp.
www.universal5.com
Orange Tool Forum
San Diego, CA
Look at the cap for your P/S Reservoir. If it says to fill with ATF, you do not have the Self Level. If it says to fill with CHF11s, you have the Self Level (Unless someone has converted the car.)Originally Posted by Vanguard
Huh? Mine says CHF11s on it though.....What do you mean converted?Originally Posted by BimmerMeUp
[1994 530i/5-Speed]
I don't think that's true. Mine calls for Pentosin 11s and does not have self-leveling system.
Mine too says CHF11S - and it too hasn't got self-levelling, and it hasn't been converted...
Mine says CHF11S. Looks like more research is required. I'm glad I checked back before ordering the parts.
www.universal5.com
Orange Tool Forum
San Diego, CA
BTW - some of these hoses are a major PIA to swap. Be sure to research before you tackle the project.
